Theta SC Problems do not connect only 5v charger 1.0A
Hello! I live in Brazil I have an SC theta and use in work Google street view. Power button press flashes red light does not turn on camera. I loaded her wall charger after problem appeared. I need an urgent motherboard thank you
#2
Did you try contacting Ricoh customer support in Brazil? I hope they get it up and running for you.
#3
Hello Friend! thanks for the feedback. I could not contact anyone authorized in Brazil! I need this urgent motherboard. please help me.
#4
@davilisboa, sorry to hear about your problem. Have you tried to return the camera to the place where you purchased the camera from? I’m in the US and I don’t work for Ricoh. If it were my camera, I would go back to the shop where I purchased the camera. I imagine that the business that sold you the camera, could help you with return. There also appears to be a web site for Ricoh Brasil. http://www.ricoh.com.br/
#5
Obrigado.
A câmera comprei de um site no Japão o qual não deram retorno e não está mais na garantia.
Vou tentar contato com o site oficial ricoh aqui no Brasil.
Caso saiba aonde posso comprar a placa mãe nos EUA por favor me diga muito obrigado.
#6
I don’t think you can buy the motherboard separately. I believe you need to ship the entire camera back to Ricoh. Your best shot is Ricoh Brazil. Did you try charging your camera with different USB cables?
#7
Olá! Obrigado pela sugestão,más tentei carregar com outros cabos USB e sem sucesso… O problema está realmente na placa mãe e aqui no BRASIL não tem suporte para theta. infelizmente.
#8
This is not recommended, but some people have taken apart the THETA to replace the battery or the MicroSD card. I have heard no success with the motherboard. Just FYI.
