Thanks, it appears as I might have to do that. Sadly, none of my friends uses Windows any longer.
Silly question perhaps, but if I register it via a Windows computer, will it still work for Live view in a MAC computer afterwards? Is this UVC register program, just a program to register the Theta S, or does it install something on the Theta S also?
What version of Mac OS X are you using? I want to try and get someone to test it with the same version. @jcasman did you upgrade your mac to the latest OS update? Does live streaming still work?
Heās having problems with the device registrationā¦
@CaptainsVoyage
try to unzip attached folder and run the Theta UVC register app
from the RICOH folderRICOH.zip (232.9 KB)
it is v1.04 for Mac
if it runs it is do to installation trouble
Regards
Svendus
or waite for to morrow
What do you think @codetricity
Windows Blender - VLC are chrashing here
VLC media player
2.2.4 Weatherwax
have send them a report
got the ansver
There was an error while transferring the data to the FTP server.
Thanks a lot for the help.
Hi @Svendus Iāve followed the installations instructions to the āTā, but I canāt seem to get the āRegisterā button to enable. Help?!
Iām using a macbook pro and have the the below:
Installed the latest RICOH THETA app
Installed the latest RICOH THETA UVC app
Restarted my computer
Launch the UVC app
Plugged the (Switched off) RICOH THETA camera
(nothing happens)
repeated the above several timesā¦ no luck
*Checked to ensure the latest firmware
*Iām running as an Admin on my MB pro
Does the MacBook Pro have a standard USB port or are you using an adapter to convert the USB cable that came with the THETA to connect to your Mac? If so, try a different adapter.
I just recently bought a Theta V and also am having this kind of trouble, I did all the workarounds stated in this thread and also tried registering it on another PC and it still doesnt work
Thanks for the extra info. Itās a little difficult for me to test this as I donāt have a normal Mac. I have a dual-boot Windows 10 machine that can also boot into Mac OS X. @jcasman has access to a normal Mac and Iāll try and see if he can run more tests.
Note that the THETA V and the THETA S use different drivers. For @Florendo_Holgado, the driver is the āTHETA Vā driver. For @Bronson_Chan, he needs to use UVC Blender with the THETA S. This is because the THETA V outputs the live stream in equirectangular and the THETA S outputs the stream in dual-fisheye.
The problems with the THETA V and the THETA S on a Mac may not be related.
I tried updating to the latest driver for Theta V and is now currently on 1.10.1, along with that I also downloaded the latest Adobe Air. Still to no avail, itās very frustratingā¦ I really need to use the live stream feature on our upcoming event I hope someone who has a Theta V and has encountered this issue and gained a resolution can help out.
I think if you upgrade Your System to Yosemite, Sierra or Even High Sierra
you solve the problem.
All right the new look in OSX migth be frigtening if you love the clacic look on El Capitain, but leaving all the bugs upgrading makes it easy to get uset to the new environment in the new better system
