GUIDE: Removing tripod & Fringing or CA on THETA images in Gimp2.8
Hi Guys here are a small guide
on removing tripod And Fringing and CA on THETA images with Gimp 2.8
We downloaded an image from the THETA Gallery
and opened it in Gimp 2.8
Note! in Gimp you do not have to turn the image around 180 degree like in you do in PS
First of all Create a new layer group and add it to the image
you merge the layers at the end otherwise it will make your image a little bit blur
Thank to Melih Yalımlı for reminding me on this point i forgot this
Filter/Distort/Polar/Coordinates
Polar Coordinates Check Polar
Zoom in press +
Clonetool Ctrl click to mark the area (50size will do to remove a small tripod)
Go Back Uncheck To Polar checkbox
All Right the image has a lot of Chromatic Aberration so we remove that also
Get the latest extension pack for windows GIMP_Extensions_v2.8_latest on this link
https://sourceforge.net/projects/gimpextensions/
to get this filters
Tips: do not install the Gimp Animation Package (GAP) if You have PS installed on your PC
the Fix-CA Plugin works best on .png and .Tiff images
when installed find it on Filters/Colors/Chromatic Aberration
find more documentation about Fix-CA on this link
Removing CA Filters/Colors/Chromatic/Aberration
Cromatic Aberation
Cromatic Aberation Settings
You Cannot save to .jpg in Gimp you have go to File/Export As
Edited-90-procent
Finished image RICOH THETA-edited.jpg low Resolution
Regards Svendus
#2
Note! the Filter Chromatic Aberration in Gimp works the best on High resolution images in tiff and do not beat the function in PS Camera Raw or not to forget the filter in Ulead Photoimpact 12
Check this Panorama (click the white hotspot in the window to see before and after CA are remowed)
#3
Thanks for posting this! I use GIMP a lot, I’m going to try using this Guide soon. Do you have a preference between GIMP and Photoshop for removing the tripod from THETA images?
#4
@jcasman Glad you liked it,
Removing the tripod in gimp are the best in Gimp you do not have to turn the image 180
as you have to do in PS,
the Polar Coordinates filter are more advanced in Gimp you get a nice workspace on the floor or roof .
Photoshop do not have a direckt filter for remowing Cromatic Aberration in PS you go from Bridge - mark the image - images right click and chose open in Camera Raw, but first with PS CS 6 and later there are this fine CA removing funktion.
Should we make a Guide with that also?
#5
Moved to GUIDE: Removing Chromatic Aberration in Adobe Lightroom
#6
Check this Panorama from Washington
The Photographer had CA on this dense Photo and missed the red green
check the colors on hats and the silver details on the stage with green CA
is it shot with a multi lens Panorama camera ?
#7
it was a nodal ninja over 1000 images Tomasz Misiewicz
All the images have to go trough Adobe Camera raw and CA has to be removed before stitching
#8
Remowe Purple Fringe in Gimp2.8
http://www.farcrydesign.com/GIMP/PurpleFringe.html
Using Script-Fu Scripts
