Using ReactVR with THETA Images
I’ve started to use React VR with THETA 360 images. It’s straightforward using the fine tutorial from Facebook below.
Original VR Scene
This is the original VR scene. The chessboard is a 360 image.
Changing Image
The image can be changed with a single line.
exploratorium.jpg is the name of my THETA image.
Changing Text
The text is also a single line and is similar to standard HTML development. The background color is also what you would expect.
Example Use
Easily add a directional cue to help your audience use the power of 360 THETA images.
