Upgrading Firmware in RICOH THETA S
[Originally posted May 24, 2016, by codetricity]
I upgraded to firmware 1.42 today using the RICOH desktop application on Windows. The big feature is a self-timer. Press the WiFi and the power button together to start the camera is timer mode. You will see a green light.
As usual, the upgrade went smoothly. I’ve been upgrading the firmware since before the camera was launched and I’ve never experienced a problem. However, I know people do encounter problems, sometimes to the extent that their camera is bricked.
The main source of the problem is that the camera is not fully charged. If the camera is under 30% charge, your chance of a firmware upgrade failure is increased.
Although there are many ways to check your battery level, I find it convenient to connect to the camera with WiFi and send it an osc/state command.
http://192.168.1.1/osc/state
From here, I can easily see the battery level.
The ‘batteryLevel’ will be one of 0.0, 0.33, 0.67, 1.0
I have a full charge. :slight_smile:
Update: 8/25/16
you can also see the battery level in the mobile app.
I have my THETA S plugged directly into the rear panel of my computer, not a hub. I haven’t had any problems using a hub, but I do have a powered USB hub of good quality. I suggest you plug the camera directly into the rear panel of the computer.
Then, I verify that I have the newest version of Adobe Air. (Screenshot updated 8/25/16)
I then upgrade my THETA desktop application. (screenshot updated 8/25/16)
At this point, I should have everything nicely upgraded and I can upgrade the firmware from within the application. The camera should be off when you plug it into the USB cable. After the firmware is transferred, leave the camera off and unplug it. Then, when the camera is unplugged, you can turn it on to start the upgrade process. The blue mode light will stop flashing and you’ll be upgraded.
Theta Refuses to live stream via USB - Error "Theta UVC Blender Status:0x800705AA"
RICOH THETA API Over USB Cable - (S, V, SC models)
#2
On Windows Go to this PC / RICOH THETA S right click chose Properties
Sorry Swedish OS : Egenskaber = Properties to see the battery 100% level before upgrade :theta:
THETA USB Live Streaming Now in Full 1080 HD - Free Upgrade
#3
・The following shots can now be taken on RICOH THETA S. You can configure the settings from the smartphone app.
-Interval composite shots *1
-My Settings *2
-Color temperature specification shots
・UVC 1.5 is now supported, so live streaming can be output in full HD 30 fps.
※1:Interval composite shooting is: when you take several photographs in succession to create a composite image that retains the bright areas of each shot. It can be useful, for instance, to take shots of the night sky from a fixed position and record the path of the moon and stars in the sky. Use a tripod to stabilize the camera when taking these shots.
※2:You can save shooting conditions set with a smartphone on the camera. Shooting conditions registered in My Settings will be enabled when you turn the camera on while not connected to a smartphone.
