RICOH Theta Stand TM-1 Available in US
Available on the RICOH site for $199.99:
RICOH THETA series dedicated monopod. The camera platform and leg are reduced in size to prevent them from appearing in a RICOH THETA’s image, and a quick-release system is adopted for the camera platform. The length when stowed is 53.5 cm (21 inches), and it can be extended up to 150 cm (59 inches) with a single touch of a button.
Nice gear, but a little pricey.
A carbon monopod and tripod base do the same job for me.
@Ingo_Pless Can you post any more details or links for specific products you use? I don’t have a good base for the Manfrotto monopod I have, am curious about what you’d suggest.
Hi there,
Pretty simple, i.e. cheap.
Has done the job so far.
https://www.ebay.co.uk/itm/XS-20-Mini-Tripod-Cell-Phone-Clip-Holder-Mount-Stand-for-Camera-Micro-SL-AA00/183064849081?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
This looks a nice tripod to stabilize the THETA. It doesn’t look like a very wide base. The TM-1 can be extended up to 150cm / 59 inches. Do you use it for those kinds of heights?
Up to 24cm between the tips on full spread.
I have used this on a lightweight 2.7m monopod at full height, carefully :slight_smile:
The price is good. :slight_smile:
The picture is helpful, thank you!
And here it is, in use, on the monopod - I find it adequate.
