PRO TIP: Remove Big Thumb from RICOH THETA Images
Stitching Equirectangular Images to Remove BigThumb using Hugin
From @looeee, originally posted to Facebook:
The first picture is made from a blend of the other two, removing myself from the image
The finished result
Standing on the one side
Standing on the other
  • Take two pictures with the camera on opposite sides rotating about the lenses. I look at a mark on the ground and keep the lenses above the same spot
  • Open both pictures in Hugin
  • Go to the menu Interface->Expert
  • Change to the Masks tab
  • Click Add new mask and draw roughly around your outline. Left-click adds a new point. Double-click ends the mask.
  • Change to the second file and repeat, adding a mask
  • Go to the menu Interface->Simple
  • Push Align (Note: this does not always work in which case you will need to add control points yourself. If there is demand I can add this in another tutorial)
  • Go to Move/Drag and straighten your image (left mouse to move, right mouse to turn)
  • Return to Interface->Expert and switch to the Stitcher tab
  • Click on Calculate Optimal Size
  • Push Stitch
